anyone know the base and max boost for the speedparts stg1/2 ecu? i got a figure of 17psi on saabnet...
also, thoughts from others that switched from a MBC to the ecu? did you lose much low-end boost? i hate to give up the quick boost that the MBC provides...did you try to run the MBC inline with the BPC after installing the ecu?
thanks for the input
eric
eric
