Does anyone here have the dumpvalve filter kit from Speedparts? I would like to see some pictures of this kit fitted...
I read on another bb that it doesn't work so well. You may just want to spend your money on a proper dumpvalve right away.
Well if you're only after the sound then it works just fine but in case you need something that can stand higher boostpressures then you have the same problem as with the stock one (since it is the stock one )
I have had it mounted on my gm900 for over two years and there's no problems at all !
No, I'm not talking about the stock one. My car has a Forge recirculating dumpvalve, so for the sound this option should work fine. I however decided to replace the unit for an atmospheric Forge...
Thanks for the replies
