Speedo needle not moving and mileometer not clocking. Also EDU at base of Instruments is dark (but using a torch I can see "life" when I push the Info button) Engine / performance is fine.
Am I correct in thinking if the speedo sender at the gearbox was faulty, it would affect engine performance?
If that is the case I am going to concentrate on electrics / connections etc behind the instruments. Is power to EDU bulbs and speedo connection on the same multiplug?
Am I on the right track?
