I had problems with a "regular" new clutch slipping whilst I was knocking out about 300lbft of torque (before I knew better
). Anyway, the concept of increasing pressure helps, and to further expand let's take a brief, simplistic look at the principles...
What we're talking about is not just friction coefficient which is a measure of friction between moving surfaces, but another property commonly referred to as "stiction". In practice what this means is that for a clutch to slip, there will be a finite amount of torque that has to be reached to break the binding (stiction). Beyond that, a lower amount of torque can maintain the slippage.
To avoid slipping you can either go for a higher pressure plate or use a paddle type clutch. Each ahs it's own plusses and minuses. I've got a paddle clutch fitted, and the plusses are:
<ul type="square">
[*]very positive bite
[/list]
<ul type="square">
[*]significantly lighter pedal
[/list]
The minuses are:
<ul type="square">
[*]difficult to feed in smoothly
[/list]
<ul type="square">
[*]gets very judderry under stop start traffic
[/list]
The alternative of increasing pressure gives the plus of a "smoother" action at the expense of the pedal getting heavier, which is a bind in stop start traffic.
The problem with clutch slippage is that once it starts, it gets worse as the extra heat generated glazes the surface of the friction material and thus reduces it's friction coefficient; it then starts to slip more, creating heat, more glazing, more heat etc... and eventually clutch burn out.
As to which to go for, it's down to a matter of personal choice. I've "taught" myself how to drive with the AP paddle clutch and the niggles about the lack of smoothness are, on balance, outweighed for me by the lightness of touch. But that may not be to your taste, especially if you do a lot of town driving. If you want to try it, then PM me. BillJ, /john, Leon and Gassy have all driven mine- maybe they would like to comment on inital reactions to the clucth too.
From memory, the AP clutch is circa £170 plus VAT from any distributor. Delivery is normally 6-8 weeks.
Good luck!
