I am quite deaf, to the point of needing hearing aids. I can't hear much at mid and higher frequencies, but am over-sensitive to low frequency sounds. This means that I struggle to hear the radio, especially speech, but road noise is more than apparent. Using my hearing aids helps a lot, but they're not 100%.
As it happens my car radio is playing up, so I'm looking at replacement options. Wandering around the local motor shop I got into conversation with one of the assistants. He clearly knew his stuff, and his advice was to start with improving the sound deadening before anything else. So I bought a couple of sound deadening pads, and spent an hour or so trimming and fitting the self adhesive pads to the boot floor, boot lid, rear valance and the underside of the steel beam that forms the underside of the parcel shelf.
I was a bit sceptical but the two pads only cost £8 each.
What a difference. The car to my ears is far quieter, and listenability of the radio much improved. I was surprised at how little sound insulation a car of this class has, and how cheaply and easily the situation is improved. The spare wheel well has a pad as standard but the rest of the rear of the car is basically a bare metal soundbox.
Still not sure about the best course of action with the radio, but I am really pleased with my quieter car!
Jack
Jack
