Hi Harry,
I'm assuming you mean the front seat bolts, which are Torx. From memory you need either a T45 or T50; sorry I can't be more precise at the mo.
They are hard work to undo because they are put in with thread lock. Although you can do it with a plain L shaped Torx key, I'd recommend using a set that fits on a ratchet.
HTH
