Dear all
Just a little tip as I'm sure I've seen this thread before in the past. My recently acquired Aero was stuttering on boost when I first got it, generally not too bad in first or second (wasn't pushing hard enough) but was quite rough in other gears if the boost guage got to the top of the broken red bit. Before I started to panic about the turbo/wastegate and all that, I thought I'd better put new spark plugs in. I took care to set them up at exact 1mm and since then no more stutter no matter how hard I push and it drives even better and generally smoother. Well worth a try if you are getting the same problem.
P.S Mike.. if you are on here, how's the new carlson going?
