1998 Saab 900SE NG convertible with 2.0 liter turbo.
This is my daughter's car. All of the sudden there is significant oil dripping from engine when it’s running.
Today I got under the engine with it running. Shone a flashlight up there. I couldn't tell where it was coming from. Oil was being flung off the belt and going everywhere, including on me. The only thing I could tell is that it did not appear to be coming from the oil pressure sensor.
What are the common culprits for oil leaks on this engine?
Discussion Starter #3 (Edited)
O.K., found the location of the leak. The oil is coming from the crankshaft seal, as you predicted.
How difficult is it to replace?
Ohioan,
This job can be done with the engine in place. Wheel off, arch ( fender ) liner off and serpentine belt off. Hard bit is getting the crankshaft pulley off. Into 5th gear, assistant holds on brakes and you with breaker bar on ( I think ) 32mm socket. Pull off the pulley then lever out the old seal. Carefully tap the new one in using the old one or a big socket as a drift. Get it to the same level the old one was at.
Re-assemble.
Paul @ Kippen.
Discussion Starter #5
Thanks. Oh, and it has an automatic transmission.
Thanks.
Assuming I can lock the flywheel, what is the tightening torque for the bolt?
