If any of you need to have your earlier 9k gearbox rebuilt, then whilst it is out I would recommend getting a drain plug fitted. It just needs a boss welding on the the casing, which is quite cheap.
This give you the ability to change the oil easily, which I understand should be considered a regular service item if you are running sginificant extra power.
