How do you remove the skins from the seats? The 900's are much easier then the 9000's. Anyone know how to remove the skins and or the rear bolts on the fron 9000 seats? How bout the rear skins? Anyone know? THX in advance!
Rear bolts are the same as the front Torx 45 or 50 from memory. Apply anticlockwise turning moment
Skin removal is quite easy. First you need to release the head restraint- push the skin down around the trim and you will see a small screw that needs to be removed in order to take the restraint out.
After that, the back unzips from the bottom, and you slowly work it up, releasing the hooks that tie the front in place as you go. The base has hooks only, all of which are obvious.
To re-skin, you will need a loop to pull the hooks from the front through the holes in the foam to re-attach on the frame.
