has any one got or know where i can get a control box for a '92 drivers seat? i can't find one in aus. also if i do find one can it be wired so the seat can be adjusted without the ignition on.
On my 1995 the electric seats worked if the doors were open (as well as if the ignition was on) This meant I could move the seat back to be able to get in when my much shorter other half had been in it! The memory seats are brilliant don't you think?
yes the memory seats are a nice touch SJ: when they work that is. as you might have noticed mine doesn't so i'm now on the other side and need a new control box. which i'm told is aus$1,400 so i'm just a little concerned that while they are nice; are they realy worth that much
they are as rair as hens teeth too which doesn't help (second hand that is).
Hi. I changed mine last year. You should be able to source one from the UK, just contact one of the companies that trade used parts. Just make sure the part no is exaclty the same, I tried a later one (different part no) in my '92 first and it didn't work.
Hope this helps
Harry
