I've just been back through the Carly's receipts that I have (back to 1995).
Scary money.
The previous owner spent £3287 without the warrenty calims in 3 years + got hit for £7055 in depresiation over 3years 3 months and 52,000m
20/02/1995 36139 84.6 mid service
02/05/1995 530.37 Front & rear discs and pads
08/06/1995 38821 20.91 warrenty Clutch master cyl vat
20/06/1995 40710 318.98 head gasket vat
26/06/1995 40710 51.83 warrenty head gasket vat
13/12/1995 49405 440.48 service + headlamp bulb, glass, osf seat memory
10/12/1996 62316 637.06 Service + ariel mast, seat memory fault, wishbone bushes, mot, battery, p7000
23/04/1997 ------ 205.79 osf seat heater element
23/04/1997 ------ 4.95 warrenty Cruise switch vat
13/05/1997 ------ 235 Repaint front spoiler
20/08/1997 71899 466.2 service + padsa
20/08/1997 71899 680 Replace rear skirt and paint
20/08/1997 72000 300 Service + mot
20/11/1997 75314 90.62 Tune and ets reset
06/03/1998 ------ Nil Warrenty Balance shafts, chains, oil pump, top engine mounts,cv gaiter
27/03/1998 ------ Nil Warrenty ETS Throttle potentiometer
03/04/1998 79029 9050 Bought
06/04/1998 ------ Nil Warrenty Service + front discs & pads, Rear pads, wishbone bushes, Reart antirollbar bushes,
28/04/1998 80512 21.39 TCS fault
07/05/1998 ------ 2.68 washer valve
18/06/1998 ------ 31.72 gas test + di test, flat spots
29/07/1998 85893 94.28 Service
25/11/1998 ------ 194.31 Service + Thermostat
31/12/1998 ------ 245.93 tyre-2 * p7000
28/01/1999 ------ 19.98 wheel balance * 4
12/02/1999 ------ 264.05 tyre-2 * pilot hx
26/03/1999 98684 117.55 Mid service + Wiper blades
04/04/1999 ------ 40 xs Windscreen
17/06/1999 102104 238.16 ETS fault, replace 2 air valves
26/08/1999 105283 188.29 Service + wiper blades, rocker gasket
15/10/1999 107663 238.13 starter motor
26/01/2000 111415 128.76 Mid service + refit rear décor panel
09/03/2000 113296 Nil vehicle inspection
10/03/2000 113296 220.62 tyre-2 * p7000
06/04/2000 ------ 58.75 Windscreen
04/05/2000 115701 158.67 tyre-pilot hx
08/05/2000 ------ 9.23 hose
---------- 102000 ---- Recover, fuel pump dead
31/05/2000 108000 64.44 Battery
31/05/2000 108000 Nil warrenty starter
29/06/2000 ------ 135.37 Heater hoses
31/08/2000 120867 192.25 Water pump
07/12/2000 124636 126.42 Mid service
20/02/2001 ------ 114.39 tyre-p7000
23/02/2001 127774 39.9 thermostat
07/03/2001 ------ 114.39 tyre-p7000
15/03/2001 ------ 58.75 Windscreen
28/03/2001 ------ 45.83 windscreen
19/04/2001 130445 123.21 exhaust centre box
16/07/2001 132000 1995 sold
16/07/2001 132000 1995 bought
---------- 132000 20 oil
---------- 138000 25 oil + plugs
24/10/2001 140788 48 tracking
29/11/2001 142286 218.23 tensioner
---------- 144000 20 oil
01/05/2002 128.5 tyre-2 * p-zero
---------- 150000 20 oil
20/05/2002 80 Gearbox rebuild
---------- 156000 20 oil
20/05/2002 ------ 135 Clutch kit
30/11/2002 ------ 50 xs Windscreen
21/02/2003 162000 25 oil + plugs
21/02/2003 162000 31.87 Cat bypass
poly bushes
Total work exluding warrenty 8175.84
Scary money.
poly bushes
