Hello,
2003 (53) 9-3 2.0 Aero Auto.
Jumped into the Car on Saturday evening for our trip to Harwich and then onto Amsterdam, only to find that the Sat Nav (ICM3) was not working properly.
Whilst on our Journey to Harwich, the Sat Nav though we were in Norfolk, when we just passing Ipswich in Suffolk?
Fiddle around with it and did the Factory Reset a couple of time, but no joy.
Has been working fine until now, can someone point in the direction to check a few things and see if I can get it back in sync?
Many thanks,
Russell.
Administrator
check the cable is located in the black box,if ok sounds like the gps ant has failing/failed..
Discussion Starter #5
Thanks for the info, will check out the cables and see if that fixes its?
I have a Top Box on at the mo as well, could that effect the signal at all?
Cheers.
Discussion Starter #7
Quick update. All ok now.
Battery went flat whilst car was parked up over last few weeks.
Whilst it was charging I wiggled the shark fin, checked the cables into the black box under parcel shelf and removed, cleaned sat nav cd.
Now works fine and got me round Amsterdam with no issues.
Thanks to all for the info on what to check.
