1 - 17 of 17 Posts
hi all hope some one can help ive recently brought a saab 9-3 tid 55 plate ... never had a saab and i love it ...but like all cars it has a couple faults that i hope you can help me with ... as soon as u turn the key the fuel needle and temp needle go up to max im having to use my trip computer for fuel on the hope that ill get at least the 200 milles to 40 pound .. also the dash says icp not programmed any advice would be much appricated thanks all lee
does it still happen if you disconnect the battery for 10 - 15 minutes and then put it back on (yes the good old have you tried turning it off and on again trick)
not sure what the ICP not programmed message is about as i can not find that error message but reading other sites, the general consensus is you will need to find a garage that has the tech 2 computer to hook it up to the car to program it correctly (this may be the issue with the fuel gauge)
Discussion Starter #4
thanks for the reply and yea treid all the old tricks bangin the dash switichin on off ..the battery was dead when i went to pick the car up ...a friend suggested the icp not programmed might have something to do with the alarm and immobiliser and that could be causing it
is that the exact error message you see on the sid "ICP NOT PROGRAMMED"?
as google isnt showing anything for it so would have figured someone somewhere would have reported it before
Discussion Starter #6
yea icp not programmed ... and appantly its immbliser related ...ive treid doing a internet search aswell thats how i came accross this site ...read some good threads and learnt a lot about the saab and what to keep a eye out for ... i live in leicester and drove to london and back yesteday 230 miles a problem so its not affecting the running of the car just dont like not know what temputer its sitting thanks lee
Discussion Starter #7
yea icp not programmed ... and appantly its immbliser related ...ive treid doing a internet search aswell thats how i came accross this site ...read some good threads and learnt a lot about the saab and what to keep a eye out for ... i live in leicester and drove to london and back yesteday 230 miles not a problem so its not affecting the running of the car just dont like not know what temputer its sitting thanks lee
Premium Member
try disconnecting battery again for 15min or so
when you turn ign off do all gauges return to 0
jon, thats also where my thoughts are, or an ICM failiure / not married to the car which is responsible for communicating with the SID and ive never heard of an ICP have you?
but this thread http://www.saabscene.com/forum/threads/120536-Icm2-to-Icm3-ECU-not-programmed
does mention an "ECU not programmed" message and states the ICM is a gateway between the Main Instrument Unit, and the SID.
so i would conclude possibly just a tech 2 session might be needed to resolve both issues (i think they might be the same)?
Administrator
I've not come across an ICP message either,which is why i'm thinking the cluster been replaced,but not programmed to the car..
Discussion Starter #12
thanks for all the info guys its much appreciated will disconnect the battery now and ill let u know how it goes ...and will get my mate to put it on his computer see if any thing comes up... and the needles do drop to zero when turned off
Administrator
if there is a problem only tech2 will be able to read all the system and whether they're communicating with each other properly..
Discussion Starter #14
hello all again ive taken the battery of and lefted it for 20 mins reconnected still the same needs stay on zero when keys out as soon as u turn key straight up to max
Discussion Starter #15
helpppppp lol yesterday the saab was running perfect went to asda came out went to start the car and nothing turned the key my clocks didnt light up the steering lock didnt click and it wont turn over ... blown about 3 30amp fuses any one got any ideas ?
Discussion Starter #17
Not sure haven't got a Saab booklet replaced all fuses now still nothing ....when I turn key the stereo works lights etc but the heaters don't come on and the clocks don't move and there's no click from the steering lock tried removing battery fully charged it and still nothing ... I'm thinking it might be something todo with my previous problem of the Ipc not programmed on my clocks
1 - 17 of 17 Posts
