What would cause this problem
Has spark (donor Dic and tested outside)
Changed CPS from donor
Has fuel pressure
Put donor fuelrail with injectors and hooked one, put fuel on rail but injectors are not opening??
If anyone sees this I probably have something wrong on injector jack, both pins show battery voltage when cranking.. Should be 12V + ground.. Continuing to check
Discussion Starter #2
If anyone is reading, the relay for pump was bad even thou you could hear the prime of the pump. New relay and it started right up...
Sent from my SM-G930F using Tapatalk
