1 - 10 of 10 Posts
Just bought above car, on way home engine management came on, no effect to running at all, purrs like a kitten, so has anyone any ideas, please no stupid replys! Thanks
Administrator
you need to get the code/s read..
Discussion Starter #3
We thanks for that obvious tip, I was wondering if there was one particular prob they all suffer
But thanks anyway
Administrator
no there isn't..that's why there are codes..
Administrator
What do you mean i'm not getting what you mean..All modern cars which have an eml on,will need to have the code/s read,there is no other way to determine what the problem is.And if you took it into a garage they would do the same thing...
I've been working on cars for 35yrs..
Discussion Starter #7
No look, I'm not looking for an arguememt, I used to be a mechanic years ago, but some cars have traits in which they suffer from certain problems all the time, a weak spot, a sensor, etc etc I was just asking if there was a weak point ie a sensor to change etc etc that's all, to start with.
Administrator
there isn't,you need to read the code/s.get the code read and post it up...
The EML can be triggered by so many things. My OBD reader was £50 a month ago. Well worth the investment
And it will turn off limp mode too, which makes it a lifesaver if you're a long way from home!
N
When the eml comes on it's letting you know something is not right
Without codes and just guessing then it's a very expensive game of parts roulette.
So as Aerojon has quite rightly suggested ,get codes ,post them up here and we can help you .
It helps us to help you and others with maybe the same kind of problems.
1 - 10 of 10 Posts
