Premium Member
We do not take responsibility for any work or method carried out from this guide, you use it at your own risk
The SS Team
Rear spring bush guide
1. Jack car up
2. Remove wheel
3. remove E18 bolt from bottom of the hub ( 18mm socket on other side )
4. Push lower arm down to allow you to remove the spring along with bushes
5. Clean spring and the bush seats
6. Copper Grease the faces and the seat where the spring will sit
7. Replace the spring / bush assembly
8. Push the lower arm back up into the hub (may need a bottle jack)
9. Rebuild is opposite of removal
Mine also had what appears to be a suspension travel sensor that needed to be disconnected to lower the control arm enough.
