So, I've finished the whole job : dismantling trans, recondition the driveshafts by cleaning and regreasing ( ?) the outer cv joints and change the boots, changed tripods, the two companion flanges ( called inner cv joints too ), the inner boots, the clips and the bearings. ( axle intermediate bearing and the one I found coming with the right inner cv joint when you pull it out off the gearbox ). The difference is REALLY noticeable, no more vibration on accel ( hard! ), no more vibes when cornering, everything seems to be smooth. We'll see if it lasts, but I think it will, as I was really carefull and CLEAN !
As I've upgraded already brake rotors ( zimmerman )front and back, pads, trans, changed the turbo, forge bypass valve, new plugs, partially new geabox oil, I would like to upgrade now the ECU. It's a 88 9K turbo, assumin it's an APC upgrade I need, wich one could I use for best results ? Anyway, the next step will be to buy a B202 engine block, complete, that I will recondition entirely, to get an "as new engine" back on the car.
Another question, is it normal that the sound when braking changes because of cross drilled rotors ?
I've got a few parts left : bearings, a few clips ( all new ), gearbox to companion flange seal, and a 2500 km used "performance bosh bypass valve ", a few rubber seals, that I would ike to exchange against a old 9000 ecu, so if someone gets intersted ....
Anyway, thank to all of you, because it's by reading the advices and the information on the several sites we all know, plus using the haynes ( wich is really NOT complete ! ), that I was able to do the whole job !!!!! What a course ! so If you have to make it and you don't know how to do it, I will transmit to any of you all the documents you will need. Keep on saabin !
Laurent and sorry if my english is not always well written ....
