hi all
ok had to pull my saab 9000 areo 97 engine and the slipping auto box after 304000 miles not bad a :thumbsup:engine had bit of crank damidge too so i bought a doner car 1996 2.3 cs its had abbotts upgrades so iam thinking nice so after 4000 miles of testing i pull engine and box with loom all fitted looking at the Ecu s mine got 4781860 on it
the doner car has got 4302980 both have got the other box alarm thing only thing diffent in the cars mine has got cruise and digy clock the doner had anolog clock and no cruise i was hopeing to use the abbotts ecu as its got the 40+ bhp on it
any help on will this be ok:crazy:
s.s.d.d.,
I'm assuming the donor car was also an automatic, otherwise there could be future problems with your 'box. the Abbott modded ecu's for autos limit the torque in low ranges to protect them from self destructing. VSS chips, I think, don't have to be sinc'ed with the ecu, they just output a signal to the ecu to say 'OK to run'. I would stick with the one in your own vehicle. Cruise control has its own separate ecu so should work all right. Not too sure about the clock but I have read of people retro fitting digital ones to earlier cars. Try a search to see what was involved.
The donor will have the Garret turbo, manual Aeros had the larger Mitsubishi one and I seem to remember that the Auto Aero was also fitted with the Garret to protect the 'box so you can pick the better of the two. Manuals were rated at 220 bhp and Autos 210 so lifting to 250 gets you up to 9-5 manual Aero territory, just be kind to your 'box, but have FUN.
Paul @ Kippen.
Discussion Starter #3
hi paul
thanks for your reply i fitted ecu yes both cars are auto took car on a 300 mile test drive over weekend away lol all good new lease of life now... Iam running the td04 turbo from the manual areo have been for some years
shes running decat full jt 3" systom too car is far from standard last auto box over 300000 miles did well
i recently bought a 97 saab 9000 cs and im wondering could i put a 97 9000 aero ecu and the turbo from the aero into my car? and will it make alot more power? thanks guys!
