I do have a 2,0 Liter TURBO Saab which the engine doesn`t work any more because the Cam is broken, I have another engine from 2,0Liter non Turbo from 1989 which dosn´t own a (DI-Cassete) this is the red part for the sparg plug on top of the engine........ do zhis old one pass to my turbo and the rect of parts
P.S: sorry for my terrebile english
Hi
Engine block is same, some internal parts (pistons, for example) are different.
Has turbo engine only camshaft broken, or something else? If other items (pistons) are OK I think it is possible to use non turbo cylinder head on turbo engine or at least parts from non turbo cylinder head.
Tanel
The turbo engine has lower compression pistons but that shouldn't matter since it is only the head that would be changed. I believe that the turbo engine has a different camshaft and that the valves are made from a higher spec material but I could be wrong. It should still work but the valves may be prone to failure in the long term.
