Hi, can anyone help. I have SAAB 95 Estate (1999) and I cannot get into reverse, when I lift the gear stick it seems light and will not engage into gear. All forward gears are fine. It is a manual gearbox. This just suddenly happened and I had no previous problems. Thanks in advance
Discussion Starter #3
Maybe a worn tong, sometimes you can get a shifter to align by re-electing between 2nd & Reverse.
Thanks you, however I found that the linkage had 'popped' off and just needed reattaching, forward of the bulkhead. I hope this helps others in future.
