Hi There Hoping someone can help me locate the automatic gearbox module on a 2000 Saab 9 5 2.3 Turbo estate took the glove box out but no joy is it under the wheel arch or something which would make sense as it only seems to be failing in wet conditions thanks in advance Russell
Do you have any codes?
Most common issue is solenoid valves sticking...or postion selector module on top of the gearbox its very rare there is a problem with the control module due to its dry location behind glove box.
