Hello, just an update and still need advice/help please.
Symptoms.
Randomly starts but more frequently now doesn't. I'm no mechanic. From researching online/youtube am guessing the fault is electrical. I put the key in turn to the the on position it makes a der-do-dum sound (like some sort of start up check routine - it always does this sound whether starting is success or fail) - FAIL - instrument panel stays off. START - instrument panel lights up. even on the fail sequence the engine will start but quickly cuts - so it feels like is some lose connection or possibly some safety sequence/contact not working properly. When it does fail to start the front radiator fan kicks in also and runs for a few minutes. Could it be an oil pressure switch ? i've made video link of the issue. hope someone can help/advise please.
also can anyone recommend a good diagnostics tool to use.
I bought a 2nd hand ignition switch, also a starter relay problem still the same. can't guarantee the replacement switch is 100% working but ebay seller said was tested and working. Also i've taken apart the key barrel, cleaned the spring loaded pin also stretched the bigger spring on end of barrel.
Symptoms.
