SAAB 9 5 2010 number plate lens
321 views 4 replies 4 participants last post by  PMKnowles
#1 ·
The bulb for my rear number plate has blown however I cannot get the lens cover off as the screws are totally rusted and the screw heads are worn.
It has been suggested I break the number plate lens to access the bulb. However, I have not been able to find a source for the number plate lens part # 13321836.
Saab parts dont appear to stock these, any suggestions where I can find the lens?
Anyone had experience on this situation?
Thanks in advance.
#2 ·
I have had a lot of luck using a hand-held impact wrench and hammer. I use a 12 inch or longer ratchet extension rod and then put the 3/8 bit holder on top with an impact-rated bit. If this setup is too heavy, step down the rig size using 1/4 inch drive pieces. Use a lot of liquid rust-penetrant and patience. It usually works well on rusted screws with compromised heads from stripping. Good luck
