Been told this is a pinch protection problem....
Do not fancy disconecting battery....!
Been told to pull fuse 5...?
Then recalibrate windows...?
My question is what does pulling fuse 5 do?
And how do i recalibrate window or windows afterwards...?
Many thanks in advance
Administrator
just unplug the electrical connector off the offending door for 10 secs then refit.
sit in the car with the door shut igntion on,no need to start engine,down,up,down up and hold should hear a chime.
Given the current weather and the thought of sitting outside in the cold trying to disconnect bits, try holding down the button that stops the rear windows opening whilst closing the offending window (Holding down the button cancels out the pinch control according to the owners manual)
good luck
i have to do my convertible every 4 months or so on the passenger window, im assuming its todo with the fact its not a solid door frame so things get miss aligned slightly
