Has anybody had a problem with the pinch protection function on the drivers side window failing. ?
I have tried the re-set mode before by using the up button for the roof raising and it has always worked but I now have a malfunction.
Co-incidentally since the fault has occurred I am getting water ingress through the top of the drivers side window - I think it is not travelling up the last millimeter or so compared with the passenger side window.
Any advice would be appreciated.
Alan.
Discussion Starter · #2 ·
Followed advice on here about removing the 7.5amp fuse at the left of the dashboard (left hand row-5th fuse up) and then followed the reset procedure in the manual and the window now functioins properly!! Still getting some water ingress which have not had before - only once and then rodded through the drainage hole at top of the door pillar and that did the trick . This time it has not resolved the ingress (but we have had a lot of rain!!)
Anyone got any thoughts please??
AlanRx
