Hi all. I have a 9-3, 2007 manual petrol. A couple of issues have come up recently. Reverse in acting strange. While reverse works there seems to be a resistance. It's strained as if there's something fighting it like the handbrake been on which it isn't. As soon as I depress the clutch the car simply stops rolling and doesn't freewheel at all. Only happens in reverse.
Another issue is a fairly load whining sound that rises and falls with the revs when in forward gears. Noise stops in neutral and when clutch depressed. Are these two issues connected? Any ideas?
Check your brakes if you don't have an issue with park rear brakes and if you don't have a stuck brake pads.. Let us know about..
