1 - 1 of 1 Posts
I have just had my saab ignition barrel repaired Part number 8960221 which happens to be the same part number for 9-3 and 900's.
My barrel was sticking and key would come out of the barrel even in any position eg. start.
Firstly you should try cleaning the barrel with alcohol and then fully dry it and ONLY use a small amout of graphite powder in the barrel.
If this does not fix your problem any good locksmith can easily open the barrel and replace the wafers (that happen to be the same as used by GM)
This is a cheap and reliable fix that costs no more than $35 AUS
1 - 1 of 1 Posts
