I have a rhythmic noise which sounds like it's coming from behind the dashboard, it is in synch with the injectors, after a little investigation it would appear that the plastic fuel line clipped to the bulkhead was pulsating with the injectors at idle, I also heard there was a recall on the fuel rail dampers (I assume for not damping enough) has anyone else had or got this problem?
