Welcome onboard Brock.
I checked the Comma spec and used 'blue' (3 year lifespan) on my Nov service, because it was approved by Saab (as stated on the container label). This will definately cover alloy heads and blocks.
The 'red' option (5 year lifespan) does not state Saab approval, and 3 years with Saab approval was my preference.
I note the blue container stated, "Do not mix with any other anti-freeze". Presumably the red does as well.
Which raises another issue.. How to get all the old fluid out!
I found that after draining the coolant, I could only get 7 litres back into the system (to the max mark of expansion tank) although handbook (for my '98 Anni 2.0L) states system holds 9 litres of coolant!
I disconnected lower hose at base of water pump, as this was the lowest and most accessible jubilee clip on my car. I had previously warmed the negine and set ACC to hot, to ensure valve was open.
NB: Do NOT use the plastic drain plug on bottom of radiator - as it usually snaps off - and being hollow, won't retain water - so your car will be out of action until replacement sourced!
So I can only assume there is up to 2 litres of old (50/50) coolant still in the system, and that bottom of cooling system (i.e. in block) is lower than the bottom hose, or the heater matrix sits lower than the supply/return feed pipes!
In any case, flush the system - and run engine between replacing coolant - to flush as much old coolant out of this 'pocket' as possible - and be sure to add all of the 4.5 litres of fresh antifreeze before you have filled up with 7 litres it will take - or the final ratio will be less than the prerequisit 50% antifreeze.
NB: Best if you add new coolant ready mixed at 50% ratio - assuming you have a suitable container to do so.
HTH,
Paul.
