got an 89 9000i for some time the rear wiper has been playing up, would wipe/would'nt wipe. then decided to pack up altogether.
would anybody have the wiring connections for the switch and the motor
cheers
gelcoat,
had the same problem on my 91' hatch,when it did work it was v.slow & didn't always make finish a sweep. My wallet doesnt like being opened,so i took the motor to bits found the bushes were a bit dirty,so cleaned them up,also cleaned the markes off the copper windings case they rub on with a bit of wd 40 & fine sand paper.Beware there is a plastic (yellowish)plate u have to snip to get the unit out.
worked a treat after that, took about 90min & saved £70 quid
G.
