I am getting a lot of ratteling from my left rear mirror at high speeds, exceeding 120 MPH! Have any of you AERO/highspeed nuts the same problem and is there any solution for this problem execpt buying M3 style ones from speedparts????
No, I've not seen that problem. When you say "mirror" do you mean just the glass or the whole housing?
If it's the whole housing, then you may just need to tighten the fixing bolts. Similarly if it's only the glass only, it may have come loose, and can be tightened via the little hole on the underside of the mirror casing
