My rear centre lights on the hatch are on all the time that the ignition is switched on, this is the same on both of my 1985 cars. On my 1987 car the centre lights come on when the headlights are switched on. Was this a change made with the face lift cars or is there another answer/problem?
odd. On pre '87 cars all running lamps come on with the ignition. (volvo style)
Check all the bulbs - maybe the others have just blown...
You could try cleaning the grounding point on the front crossmember and the one in the boot. Try removing the daytime running light fuse to see if that helps..
on my 1987 T8 the rear lights on the hatch only work with the light switch like they should..
but I have noticed my mates 1992 T16S hatch lights don't work at all same as Rages T16S hatch no lights unless he's fixed his now
Paul
_______________________________________________
Sleeper baby, no show & all GO.................
