Hey now, here's a problem I've not seen posted before. Yesterday just after I started the car I needed to get something from the boot, and when I was at the back I saw that the brake lights were on despite no brake pedal activation. Subsequent investigation revealed: when rear window heater is on (either automatically via ACC or by manual switch) the brake lights come on; when the brake pedal is depressed the brake lights work OK, but the heater indicator on the dashboard also lights up (not as brightly as when the heater is on "properly"); if the rear window heater is on (and therefore all brake lights are also on) and the brake pedal is then depressed then the main brake lights remain on, but the high level light goes out.
I would guess a wiring issue at the back of the car is to blame, however ... for some time I've had water dripping in from the overhead light / switch position and wonder if this water might have found its way into the wiring /switches at the front of the car.
Any views / thoughts?
