9-3 turbo estate
Hi,
The rear off side LED brake light cluster on my 2006 93 turbo estate has started to flicker. It lights up as normal when the brake is applied but flickers when off? Any ideas... only off side affected.
The main reason for the headlights blinking is a voltage fault. It can happen for several reasons. One of the most common is battery malfunctions. Btw, I ran into the same problem last week. Therefore, I decided to change the lighting to LED. Moreover, I also changed the light bulbs in my apartment to https://www.vont.com/product/vont-bulb-color-smart-light-bulbs-smart-bulbs/. Btw, there may be too much load on the onboard network. Powerful radio equipment and heater can cause the headlights to blink due to voltage drawdown.
