Right I can see from my wiring on the Delco Grundig Sat Nav (pics) there is L (+/-) R (+/-) and ground for Aux In
Ive found this harness but want to be sure it works and does not need activating or so on... (pic)
Discussion Starter #3
Bluetooth music receiver 5v 2a with 3.5mm jack to twin rca to wiring harness above to saab head unit
so it can be hide away rather than all dangling cables coming out the front aux....
Discussion Starter #4
Yeah go on then mate....
wernt getting any real response... just stick it in the front..... which is pure clutter of cables in my view....
That pic on the left at the top . Is the one you are referring to the red circurled one ? Seems like it ,
But the photo has chopped off the pin connection numbers . .
I don't know if that maybe the aux for say a boot multichanger ( if they ever did that option )
Not knowing much about adding Aux , may well require adding Via Tech 2
