Andy,
The fuse for the DRL hasn't been removed- it just wasn't fitted for the UK market. On the 900CS, all it does is illuminate the sidelights, which on the CS are only 5W lamps, and not terribly bright.
If you want to having noticable DRLs, then you could leave your headlight switch on permanently, as they only come on when the ignition is on.
