After having the MapTun stage 3 ecu fitted to my 9k aero I went ahead and did the air box mod and took the CAT off. Should I have sent the ecu back for re-mapping?
Also I'll soon be putting on an Abbott intake pipe and hopefully a bigger intercooler. Will it be necessary then?
thanks
Zahid
you will probably be ok
the mods should make things go better but should not cause the parameters to stray off the "map"
the other thing is that the ecu will adapt
just be aware that at the outer edge of stage 3 if you use an MBC it could make the fuelling marginal
the std set up is good for 300-310 bhp which is also about the max the tdo4 is good for you can go further but the experience here is that the mixture will lean out and you are into problems
which would necessitate bigger injectors ,bigger fuel pump and then you will definitely need a re-map
Thanke ylee. Looks like stage 4 then The car is currently running approx 300bhp so stock turbo is fine I guess.
BUT I WANT MORE, Mawahaa ha!!!
(btw, good result on the dyno mate!)
