Hi,
I currently have an MBC fitted to my car, the reason it was fitted was because of erratic boost delivery, which I think was the first signs of the DI failure rather than a problem with the APC.
I have now decided to refit the APC and disconnect the MBC, can anyone please tell me what hose goes where on the APC please ? and make it really basic !
Many thanks
Andy
the pipe to the wastegate actuator goes to the middle tap on the wastegate solenoid, the pipe and the tapping should have a 'w' on them both.
The tapping on the compressor side of the turbo goes to the tapping on the solenoid with a 'c' on it can't remember if it's top, but it really is labelled.
Finally the last pipe goes from the inlem plastic piping to the 'r' labelled solenoid tapping.
Top outlet on APC solenoid - labelled 'C'- goes to nipple on turbo compressor housing (probably where the input to your mbc comes from at the moment).
Middle outlet - labelled 'W' - goes to wastegate actuator (most likely where the outlet of your mbc goes to at the moment)
Bottom outlet - labelled 'R' - goes to the nipple on the inlet pipe to the turbo (the bit between turbo and air filter)
Manyt thanks for that
APC is all fitted up and working nicely again !
Is an adaption run necessary once again ?
Andy
