1 - 9 of 9 Posts
I have got a radio/cd from a 1995 saab 9000 to replace the units in my 1991 car, on taking the old units out the wire blocks are diff from the new one. The old one has a 6 block with 4 wires on it that i think will be the power wires + 2, 7 pin din(round) plugs one for the cd, one for what i take to be the amp plug. The new one has two blocks at the back one with 8 pins, one with 10 pins, can i get 2 converter blocks for the amp and power for my old wires
Discussion Starter · #9 ·
has anyone changed the radio/cass and still used the built in amp, if so do you know if i can get a lead from saab to let me use the old connector as i think the cs has 2 or 3 diff connectors built in but i cant find anything else behind the dash in mine,i really dont want to replace the amp as i am happy with it and i know the new radio/cass + cd work ok, i cant even change the cd over as the lead is diff as well vonly the cd is u/s
1 - 9 of 9 Posts
