While trying to locate a water leak on the car today I broke a wire coming out of the radiator thermostat plug thingy. Bo**ocks thinks me...but then I noticed that there were only two wires coming out of the thermostat to the plug, and three out of the plug??? Fortunately it was the third un partnered wire that had broken. I just taped the broken ends over and nothing seems to be the worse. But, what is this third pin for? Should there be a third pin present?
Kev
Two speed fans were very rare in the UK. it may just be that the wiring loom is the same for either type though. If however there is a resistor bolted to your fan, then it should be a two speed 'stat.
