I have recently purchased new poly anti-roll bar bushes for the rear of my '97 9000. However I am having difficultly in undoing the bolts to remove the old ones, even after copious amounts of WD40. I have read various posts about bolts shearing off so i'm reluctant to use as much force as I can. Anyone have any ideas on how to loosen these bolts or should I just head to a garage and get them to do it (anyone know roughly the cost for this)?
Thanks in advance.
when i had this problem on my 89 9000i, i used a small wire brush to clean the threaded parts of the bolts that i could see, i cleaned them up as best as possible and kept spraying penetrating oil / fluid over the exposed threads for a couple of days before trying to undo them
hope this helps
Hi,
Is there much corrosion or dirt around the bolt assembly?
When I did my 1998 9000 ARB bushes, front and back, I found bolts removed quite easily after a modest application of WD40. I let the WD40 soak in for 10 minutes before applying the socket/ratchet.
With any luck, a clean and soak, you should be well on your way?!
And you should notice a distinct improvement in anti-roll once job done!
You may want to try Plus Gas rather than WD40. Plus Gas is far superior at penetrating rusted fastners. You could also try heating the area with a propane torch. The other option is an impact driver.
Finally managed to fit the new rear arb bushes and all i can say is............WOW what a difference
Was fairly sceptical about how much of a difference they could make but I'm gladly mistaken. It is almost a different car round corners.
What other cheap and easy modifications can I make to improve the handling of my 9k?
