tooling around with my car on the way back from work nothing unusual just putting the pedal to the floor sometimes when one of the times i decided to step on it from 2nd i watched the boost gauge clime to 12psi and stop while still at 4500rpm in 2nd i put it in 3rd usually spikes a little over my regular 15psi that i run with MBC, and it still only made 12 psi, pull over crank the MBC all the way up still only hitting 13-14psi.....no visual vacum leaks boost gauge acting fine beside the car isnt hitting boost its soposed to !!!! , i cant even get fuel cut if i want, usually i set it right perfectly at 15-16psi so it wont hit fuel cut at 16+ psi, now like i said i cant even get there if i want,
i got a 87' 9000T,
thanks
i got a 87' 9000T,
thanks
