9.5 Wagon Aero Hot on a 52 plate.
Every now and then the parking assist just stops working and I get the message on the display. After a couple of days it's fine again.
Any ideas?
steve
Make sure the sensors are clean, if they are you might need to remove the sensors an clean the contacts.
To remove press the sensor firmy in and then remove it and the colllar and unplug it then and clean the plug and socket
Sadly that removal method only works for the earlier models- later ones you need to take the trim off. It's a right royal pain.
