Hey guys anyone know where to get paint pens or touch up paint. As I have a few scratches on the hood and door and on my roof....Also has anyone had good results with these paints???...my scratches are only down to the white primer no metal showing.
gundam_007, you can get touch up paint / sprays from your Saab dealer or specialist - or from an automotive factor who can mix up the paints for different vehicles.
Application of paint is the key to a good result - Saabman may have some good advice on this for you - I am sure a link was posted a while ago to a site with tips and tricks on this - try a search on SSc for the link.
HTH
gundam-007 have you a metalic finish or a straight colour?
If a straight colour apply many coats until the scratch is filled slightly proud of the original paint,then lightly sand the finish with 2000's grade (mirror finish) wet and dry (use wet)until the touch up is level with the original paint,then polish up with a mild cutting compound.
If a metalic finish base up the scratch with the colour and then build up with clear laquer to fill the scratch and then follow the above procedure.
Take your time and good results can be had
