Hi all
Having been set right about my boost gauge I need some help with the DCC computer on my 2.0 Turbo. It shows an F2 error code for the outside temperature.
Can it be fixed? Where is the sensor located for the outside temp, I know it is in the front bumper of my 900, not sure on this one though?
Thanks in advance
On a 1990 model, the outside temperature sensor should be under the front bumper, on the passenger side.
There is a small rectangular hole with a folded metal plate over it, and if you unbolt this, the sensor just pushes into it from behind.
Hope this helps
