Have just fitted the aux guages to the 9k aero and just want to know if the oil pressure guage is working properly. The guage shows 1 - 5 bar and when the car is running the needle is constantly at just over 5 bar. When I turn the ignition off the needle flickers a little and rests at the end of the scale at the 5 bar position. Does this sound ok
cheers
Zahid
My oil pressure when cold peaks around 4 bar, I'll take a good look tomorrow Zahid. Once warm it drops to around the figures Leon is mentioning.
Nick.
Originally posted by ZARS:
[qb]  When I turn the ignition off the needle flickers a little and rests at the end of the scale at the 5 bar position.  Does this sound ok
Zahid [/qb][/b]
No, not at all.
The gauge should drop to reading minimum with the ignition off. It sounds like you may have a wiring problem.
Thanks guys. Did think that maybe the wiring has been put on the wrong way round
Bubbles, I got it wrong, when the ignitions off the needle does come to rest at the mimimum side of the scale (eventually)
