I have fresh oil leaking at the distributor, had cleaned engine to check, is this an o-ring, seal or part of the head gasket that is leaking.
Is it straightforward Saturday repair job?
The distributor fits in with an O-ring and should only take a few minutes to change.
Just mark off the position relative to the head and refit as close as you can.
The distributor is not timed like on older cars so the rotor just needs to be passing the right cylinder contact at about the right time to work correctly.
