Hi Chaps, I have a 9000 V6 with a problem. I know I shouldn't have bought a V6 - I should have read here first but I'd really appreciate some advice.
The cylinder head gasket(s) failed some time ago dumping oil in the coolant. The oil loss was not noticeable but the car was a little sluggish. The oil in there attacked the rubber in the hoses and the first I knew of the problem was a cloud of steam when a weakened hose burst. The gaskets are now replaced by a Saab specialist on the South Coast and they also tried their best to get all the oil out of the cooling system. Shortly after the repair the little remaining oil managed to clog the radiator - that's now fixed. But I still have been able to draw off small amounts of oil from the top of the header tank over the past few days.
Now my questions - Is there some chemical that will disolve the remaning oil to remove it completely - and thinking laterally - is there somewhere else (other than the head gasket) where oil could still be leaking into the cooling system. I would love to see some detailed drawings of the insides of this engine to see if a crack somewhere might result in this - such as around the water pump or somewhere else in the block. I'd appreciate some insight into this problem.
Thanks in advance
Ken
PS The V6 despite not being a 'real' Saab motor is quiet, smooth and fairly fast. I manage to get roughly 28 MPG from varied driving.
Thanks in advance
Ken
