1 - 8 of 8 Posts
I am still having an occasional misfire which I first thought may be turbo related but now i think it is coil/ direct injection related.
It is possible to replace indivadual coils from the cassette and if so who sells them?
If not available I don't want to shell out on a full price cassette so is there someone near by me with a spare or even a sound one that i could borrow for a test drive to see that this is the problem.
These things seem pricey and i haven't found many saabs in the scrap yards.
Nik
nik
Before you do anything so drastic, take off the DI cassette and squirt some WD40 down each barrel - this may work. Not my moment of inspiration...full subject can be found elsewhere on this forum
Nik - what are the symptoms of the mis-fire. DI misfires have pretty well defined characteristics.
The DI cart, although having lots of Torx bolts on its underside doesn't seem to come apart too well (My brother and I are considering trying it just for an experiment) - so you are looking at a whole new one (and I guess you could argue that if 1 coil is on its way out then the others are probably not far behind).
Steve
Just out of interest what petrol are you using?My Gm900 used to misfire at idle when running on Optimax. I changed to Texaco and the misfiring stopped.
Al
Steve
My auto would still do it in D with foot on the brakes as well as in N but never, never through the rev range. Seriously, if you are running Optimax, change brands for a tankful or two and see if it disappears.
Al
Thanks for tha advice so far. I have had the cassette apart - no problem. I cleaned up the springs and the ends of the coils and applied some copper grease to ensure a good contact.
The coils are full of oil and can not be topped up.
When i put it back together is was fine on the first or second run before the misfire returned- perhaps the fiddling and movement improved them temporarily????
Originally posted by nik:
[qb]and applied some copper grease to ensure a good contact.
[/qb][/b]
That might be the cause of you problem... if any of the copper grease has made it into the lower section of the boot, then it could be forming a path that's allowing arcing. I would disassemble it and clean it thoroughly.
I've posted some info on cleaning DIs here in the Performance section
1 - 8 of 8 Posts
